# Euler buckling simulation
**URL:** <https://www.simscale.com/forum/t/euler-buckling-simulation/62184>\
**Category:** Solid Mechanics / FEA\
**Created:** [January 18, 2017, 8:55pm UTC](https://www.simscale.com/forum/t/euler-buckling-simulation/62184 "2017-01-18T20:55:47Z")\
**Showing post:** 12
**Author:** ![rszoeke](https://www.simscale.com/forum/user_avatar/www.simscale.com/rszoeke/32/14_2.png) [@rszoeke](https://www.simscale.com/forum/u/rszoeke)\
**Post date:** [February 12, 2018, 3:17pm UTC](https://www.simscale.com/forum/t/euler-buckling-simulation/62184/12 "2018-02-12T15:17:09Z")
Hi @gkotelnytskyy,
as long as you know in which range the critical load will be. this might work.
I made a small example, with a fixed end + pinned collumn under compressive load: [Buckling Test by rszoeke | SimScale](https://www.simscale.com/projects/rszoeke/buckling_test/)
From hand calculations the critical load should be about 30.31KN.
The nonlinear analysis shows a buckling behavior between load step 0.7 and 0.75, at an total applied of 40KN, whis is betwen 28KN and 30KN:
 ![buckling](https://www.simscale.com/forum/uploads/default/original/3X/3/f/3f30ca22cd56b6fbcc9a6d21431212442538b994.png)
Richard
_[View the full topic](https://www.simscale.com/forum/t/euler-buckling-simulation/62184)._
