Error codes when applying the external flow volume or looking for interferences
I receive a error message when trying to apply my external flow volume on my model:
Found in the forum it could be because of interferences, however I receive the following error message:
Do you know how to solve this?
My project:
Matti
Hey Matti, and thanks for using the forum.
I will investigate the issue and reach back later.
have you found any solution to this?
Matti
Hi Matti, and sorry for the late reply.
I made some tests and trials but could not find a solution.
Could you please try to export your model in a solid format such as Parasolid or STEP? Also make sure that all the exported parts in the model are solids and not surfaces.
thank you for your reply!
I cant find any option in either Revit or AutoCAD to export those formats.
Is there any other solution?
Matti
Perhaps this article could give you some ideas on how to use a Revit model for CFD:
