SimScale CAE Forum
Erroneous Mesh
I re-ran an old mesh in this project without changing any settings but it fails
Hi @hnassar!
Having a look at it later on and will get back to you asap.
Hi again @hnassar!
Can you tell me what mesh you are referring to? I also changed the link you posted as the one you added was not yours. The more information you provide us with the better.
Thanks a lot and cheers!
The first one. I am trying the third one now it has less error cells
https://www.simscale.com/workbench/?pid=2229608000015859655#tab_0-0 Mesh “Copy of Model-Conf-1-2 mesh 2” failed
Hi @hnassar!
I have made some adaptions on the mesh and invited you to the project. Give me some feedback if everything is fine!
Cheers and have a nice weekend!
Thank you I will try but i don’t understand why it would fail now when it succeeded before
could you explain the problem and specify the changes and why you chose them
Hey @hnassar!
I simply reduced two refinements of you and went from level 7-8 down to 5-5 as well as reducing the number of cores to 16 which turned out to work in this case. :wink:
