'Dynamic crash' simulation project by pgaviria
I created a new simulation project called 'Dynamic crash':
car crash
Hi @pgaviria, this looks like a fun simulation! Let us know on the forums if you need any help.
Hi @pgaviria, Your project seems to be really interesting to work upon. I have made some following changes as follows:
  1. I have given suitable material properties to both the structure of the car as well as the wall.
  2. I have fixed the wall and also added certain velocity to the car so that it strikes the wall
  3. I have also made some changes in the numerics and simulation run so as to obtain the result in a shorter span.
    And then carry out a simulation run.
    Do have a look below in the project with all the above mentioned changes.
    https://www.simscale.com/workbench?publiclink=64e885f0-e16c-43c9-80d5-1112d63830a7
car crash dynamic simulation result
Above picture shows just one frame of car crash with the wall.
One suggestion that can additionally be done is to prepare a car model in which different material properties can be assigned to different parts of the car so as to properly analyse the crash behavior of the car. For example : Plastic materials for the bumpers, Aluminium for the shell of the body, Rubber for tyres, Glass for the windscreen etc…
With Regards
Shiv Ohri
