'Ducted fan - CFD sim' simulation project by dheiny
I created a new simulation project called 'Ducted fan - CFD sim':
A 3d printed ducted fan
@Ali_Arafat - transient run seems to make troubles. Any hints?
Fine mesh run meanwhile also in there - yPlus actually is so low that the no wall function would be necessary to capture the boundary layer.
Pressure distribution on surface:
#5
Hi @dheiny
The possible problem could be that the mesh for the Rotating zone is merging with the casing. See snap below,
I suggest to have a clear gap of atleast 1-2 cells between the boundaries of AMI zone and casing.
I hope this helps.
Ali.
#6
Hi
Very cool. Was it possible make fan rotate in simulation?
With best regards,
Juho
#7
Hi @TmReijo!
Indeed the fan rotates using the so called Arbitrary Mesh Interface (AMI). You can find more information about AMI and Multi Reference Frame (MRF) here: Rotating zones - MRF & AMI
All the best!
