'dsfdsfdsf' simulation project by flyed42
I created a new simulation project called 'dsfdsfdsf':
dfdsfdsf
Nice CAD model @flyed42!
Please make sure the geometry is watertight - first start closing all the open sections of the geometry as well as defeature it by removing all the components that are not necessary. On top of that split your geometry into different faces to make sure the mesher does not run into trouble. If you want to make use of the MRF approach make sure you enclose rotating parts into a cylinder!
SimScale is here for you if you need any help with your project!
