'Drone_Blade_Analysis' simulation project by Bjoern_Lau
I created a new simulation project called 'Drone_Blade_Analysis':
effect of number of propeller blades on the lift and drag/torc of the drone
Geometry 1 : - 3 Blades; 8deg angle of attack
simulation with Step-by-Step-Speed 2100rad/s and homework 1200, 1600 and 2000 rad/s
Geometry 2 : - 4 Blades; 6,6deg angle of attack
I wanted to see if the increase of the number of blades by 1/3 and decrease of the angle of attack by 1/3 results in diffrent liftforces of nearly the same.
The plots show that one blade more has a larger influence than the decreased angle of attack.
