'Drone aerodynamics Project' simulation project by rochtar
I created a new simulation project called 'Drone aerodynamics Project':
aerodynamics performance for a propeller
Hello @rochtar,
I quickly checked on your project and saw that you have two runs with the same error. If you check the event log you can find the reason for this (Click on your Run and find the Event log in the settings panel (mid panel) at the bottom.
You assigned a wall bc for your drone and added the faces of the rotating zone as well. For a rotating zone no bcs are allowed. You would artificially add a cylinder geometry otherwise.
Hope that helps!
Best Alex
