Hello, Can you please tell me why Non-orthogonality and Aspect ration is getting high in my current case. I mean its a very simple problem, Just a closed sphere. Please check my case and suggest solution.
Thank you for reply.
I want to simulate dust inside the sphere. But in the Current stage i just wanted to use “Air” as a fluid. Wanted to know behavior inside the sphere. Only small mass is going inside comparing the sphere volume. In my problem only one opening is there. Another openings i have not modelled yet because those are vent, Vacuum pipe line etc. , which are not part of this process/simulation. But it is showing error, like diversion or mesh quality etc. Geometry wise problem is very simple. Please guide, I have added link in my previous post
Hello, I used default setting in the mesh. Standard algorithm, No boundary layers etc. Now, my mesh problem has been resolved. Thank you for the support !
Hi there, thank you for your patience, always feel free to tag me if a forum post stay unresolved for a long time!
Is it possible to import your model to STEP or Parasolid instead of STL please? This could be the reason the mesh keeps failing, as STL is not suitable for this type of meshing and analysis.
