'Disc Rotor' simulation project by mpasquon
I created a new simulation project called 'Disc Rotor':
Copy of Disc Rotor
Nice model @mpasquon! What do you want to investigate with your heat transfer simulation? Because of the small convective surface the model seems to adapt almost instantly to the prescribed temperature of 400 K. I did a quick steady-state setup and a transient simulation over 0.5 seconds (stretched in the video) to showcase how fast this happens https://www.simscale.com/projects/afischer/disc_rotor. Even in the first timestep only the blue parts are not already above 399 K. Is this the real world application or do you actually aim for introducing the heat via a surface heat flux bc? I am happy to help if you need assistance.
Best Alex
