SimScale CAE Forum
'DI Tower 2' simulation project by rhankinson
I created a new simulation project called 'DI Tower 2':
DI Tower 2
Hi @rhankinson, welcome to SimScale!
I wanted to point out a few issues with your setup:
  1. You’ve applied the constraint and the load to the same end - the constraint prevents the nodes from moving at all hence you will not see any stresses in this case. I would suggest constraining the faces on the opposite end of the structure
  2. The model that you’ve uploaded contains 4 solid volumes. Thus, you must set up contacts (under the Domain item in the Simulation Designer) so that the solver knows that the parts are all connected.
Hope this helps and happy simulating!
Anna
