Creating enclosure failed
I am currently trying the optimize a bus model for a school project. In order to analyse the aerodynamics of a back I created, I am trying to make a simple simulation. The enclosure operation fails and it says I need to consider “cleanup operations” allthough I dont see any problem with the face in question.
Thank you very much for reading!
The project: SimScale
Hi Louis, would it be possible to try and upload your model in STEP and/or Parasolid format as well?
I will try that for sure :slight_smile:
Still the same problem, only now it is 2 faces that need to be fixed :confused:
Well, i went back in fusion and deleted alot of faces, allthough it looks worse now, it works I guess
It seems the Enclosure was created for the STEP file :slight_smile:
In the future, make sure to check this page that includes tips on how to fix faulty faces: How to Find Faults in the CAD Model? | SimScale Knowledge Base
Yep, I did like 5 iterations of deleting faces, allthough I still dont know why the original wouldn’t work
