I am trying to simulate conjugate heat transfer between 3 solid regions. I used a multi-region OpenFOAM mesh. The region in the middle “core” has a volumetric heat source. The boundaries are all assumed to be at 300 K. I defined the coupled interfaces under the domain. The case check runs fine. For some reason, I get “Error” when I run the case. There is no log or anything specific given.
Link to case: https://www.simscale.com/workbench/?pid=3476408242162835414
Please check the case and let me know what is wrong. I can’t even access the files for the case. It’d be nice if you allow people to access the OpenFOAM case so they could at least know what is going on. We are assessing whether or not to use Simscale for our future projects.
