Collaborative simulation project? Multiphase flow around a boat hull
@quequen
It would be great to have this simulation as a part of the library! In case you would like to publish this project, or have any issues with the simulation, please share the project here.
Meanwhile, like @dheiny said, I’m working on a similar project. As soon as I have some results, I’ll update here.
@sjoshi, it will be nice if you can join this project too. I’ll be glad to see this project in the library, you can use the geometry freely, it’s of my own, so no copyrights involved.
Any tips on how to define the 2 phases?
@dheiny, seems like something happened with my account when I subscribed to the forum, now it is a basic account and no longer an academic one… can it be fixed?
It will be great if Simscale accept .iges files, they are easier to handle.
I have many doubts on the geometry:
Must the water plane go into the hull? My waterplane is cut by the hull skin, it has a hole where the hull lies. I don’t know whether is it right. I’ve seen many simulations where waterplane goes into the hull.
Must the hull be splitted by the waterplane? Mine isn’t.
@quequen
Thank you! I’ve requested access to your project from @dheiny, and will begin work on it soon. Meanwhile, I’ll try and address some of your questions.
I think the following procedure should give you access to the academic account:
  1. Log in to your SimScale account.
  2. Click on the My Account button (located on the top-right of the platform interface)
  3. Click on Upgrade Plan button. This will take you to a new page.
  4. From the two tabs (Commercial and Academic), select the Academic tab.
  5. You should be able to select the Academic Plan then. In case the problem persists, @agata could help you out.
Sure! Once you create a new simulation, the initialization of the phases can be done using Geometry Primitives ([details here][1]). Geometry Primitives can be specified under Simulation DesignerSimulationDomainsGeometry Primitives
How it works is, in the Phase Fraction part of the Initial Conditions tab, we switch to Subdomain-based option. Then, we specify the Default Value of the phase fraction. This initializes the entire domain to that value of the phase fraction (say 0).
We can then use a previously defined Geometry Primitive (lets say we use a Cartesian Box), to initialize only that part of the domain which is occupied by the box to the other phase fraction value (in this case, 1).
You are right, it is not exactly how one would want their boat to sail as :wink:, and we are looking at introducing more specific ways of initializing the domain in the future.
But I think it does not affect our simulation to a big extent. This is because we are not including Fluid-Structure Interaction, and hence presence of water in the boat does not affect the buoyant forces on the boat. It does change the movement of air inside the hull cavity - which can be safely ignored if the focus is on drag and wake studies on the outer surface of the boat.
One workaround could be to fill the inner part of the boat with solid material, so that it is not counted as a part of the domain.
[1]: SimScale Documentation | Online Simulation Software | SimScale
@quequen, I checked you account history and it seems you just subscribed to the premium test on August 1st. Feel free to upgrade to Academic anytime and enjoy the full power of SimScale! Let me know if you have any trouble.
thanks @vdoelle1, @sjoshi, I updated my account to Academic.
Have you considered to save a small tutorial to explain the settings?
Can the Documentation be downloaded as .pdf?
@quequen, I am currently in the process of wrapping up the simulation in a state that can be shared. Once that is done, I will share the simulation here and it can then be imported in your library.
We have some results: the geometry for now is the original one that @dheiny used. It was initially refined to a high level of detail, but the element size there was too small for the simulation to finish stably in reasonable amount of time. So the mesh was coarsened a little.
The boat sails at a speed of 2 m/s, and I ran the simulation for about 38 seconds of simulated time. Here is an animation of the interface. We can clearly see the formation of a stable wake over time.
Fast progress @sjoshi ! If your boat travels at 2m/s then it seems to sail at Fn=0.23 Distance between wave crests should be about 2.56m and your LWL should be about 7.7m
Are this values close to reality?
Transverse wave system seems ok, however I would expect a divergent wave system more clearly visible. Perhaps domain width is too small?
Why are the highest waves flattened on their crests?
I think I’ll wait for your simulation to be finished before making more attempts with mine, too many things to learn yet !.
@quequen
Thank you for the data! I did some quick calculations. The Waterline Length l_{WL} of the boat is 6.7 \text{m}. Based on the relationship between hull-speed u_{hull} and l_{WL}:
$$ u_{hull} = 1.4393\sqrt{l_{WL}}=3.73\text{m/s}$$
So I think I’ve underestimated the speed! The Froude number can be computed as
$$ Fr=\frac{u_{hull}}{\sqrt{g_0 l_{WL}}}= 0.46$$
According to [references] (http://www.prirodopolis.hr/daily_phy/pdf/speed.pdf), the wake angle \theta_w for boats travelling at hull-speed is usually 19.5 degrees. Assuming we’re interested in a wake region that is approximately 10 times the l_{WL}, I’ve modified the domain size to include the entire potential wake region. I’ll now run a simulation with the right speed and geometry bounds, and will update with results soon!
Thank you once again for the observations. This is exactly why forum discussions are so productive. :smile:
Based on @quequen’s suggestions, I modified the domain size and supplied the correct input velocity. I ran a short 3 second simulation just to see how the wake starts developing, and it already looks much better than last time.
Waiting now for a 20-seconds run to finish.
Wow! now the transverse wave system is cool, showing his typical curvature. Diverging system still don’t appear.
Check depth, shallow waters (assuming non-adiabatic walls of the domain) should have a strong effect on wake, even making the transverse system disappear. But even then, the divergent system should be there (Edit: but not in the same way! ).
Distance between crests now concur with Fn=0.46 (slightly longer than LWL). Although Fn=0.46 is pretty high for the kind of hull you are analyzing. If the hull has not vertical freedom, it will lead to error because the amplitude of the wave under the hull will make the yacht “lighter” (less water displacement than really needed). There is a way to simulate this in a more realistic way: sink the hull slightly at the beginning of simulation so that, when at Fn=0.46 , the water volume displaced by the hull still equalls yacht’s weight.
About Kelvin wedge, some concepts can be considered beforehand:
Divergent system is always there, no matter the yacht velocity, hull shape or water depth, (Edit: but it can widen a lot in shallow waters!) .
Transverse system appears at low Fn up to, say, 0.6 At higher Fn the hull may be planing and then it dissapears completely.
Transverse system can dissapear in shallow waters even at low Fn.
The tangent angle inside the divergent system isn’t constant: It goes smaller when Fn goes higher.
Longitude of transverse waves is proportional to yacht velocity only.
Amplitude of transverse waves is proportional to yacht velocity and yacht displacement, and may be affected by hull shape.
Typical Kelvin wedge behind a ferry, traveling at about Fn=0.3 or 4.9 m/s (taken from Google Earth)
LWL: 26.5m
Distance between transverse waves: 19m
8 second Simulation visualization. As per @quequen’s observation, for Fr=0.46, both diverging and transverse wave systems appear in the beginning but then are lost - probably because the domain is still too small.
Now running a simulation with domain four times as big.
Hi @sjoshi it’s great someone continues this thread!
As @quequen seems to be a bit deeper and up-to-date with the topic of hull’s design – I had the lectures and some practice years back now :slight_smile: – I’d still like to add something from me.
I’ll focus on your last outcomes as I assume these are the best one so far. So I took your animation, cut the very last frame and this is what I’ve got:
(Sorry if I missed it in text.) Roughly measuring the distance behind the hull is about ten times the length of a yacht. The width is more than five time the hull’s width – I like it. But what I don’t like and don’t understand is why there is such a small gap between domain inlet and yacht’s bow? Look at the picture above (and your earlier picture, orange one too). Didn’t you notice that? (Sometimes it happens that we miss obvious things :slight_smile: )
I assume the water table is expected to be flat (no waves), but here we can see clearly some wave is forming in front of a bow. – The same phenomenon you can observe in your previous simulation (!) - I would say you should move the object further down the domain and I would keep the other dimensions as they are. It’s nice to read your discussion about wake shape, but don’t forget about what’s happening in front. BTW residuals go smooth and stable with it?
Also: the time step here seems to be 0.1 [s] (animation contains of 81 frames). It’s fine. But with domain size at 30 [m] and velocity 3.73 [m/s] the time of 8 [s] you set hardly covers (or even doesn’t) the time that a particle of water needs to travel from the inlet to the outlet. If you start your simulation with zero velocity it’s not enough.
You have written you had quadrupled the domain size. Personally I think it’s not the right way. Not at this point. First I’d like to get rid of that wave at the inlet, obtain smooth and undisturbed inflow and only then move my attention to the wake.
So please, if you could run this simulation in approximately the same domain, but move the object about two hull lengths back. You have the precise values, but I’d like to ask for domain and object placement like this:
And, if you start with zero velocity, I’d like to see results after at least 16, maybe even 18 seconds minimum.
Big PLUS for you for running this simulation with full hull, without symmetry.
Finally, could you paste in velocity and pressure fields at symmetry plane? @quequen mentioned something about shallow water and draught, so I’d like to see if there is any influence of domain bottom at it.
Sorry for the hiatus! There were multiple things in the simulation definition that needed correction. I will summarize them here:
Domain: The aim of this simulation was to capture the Kelvin pattern of a boat. As described in depth by @quequen, this required a certain constraint on the size of the domain (19 degrees spread on each side). Also, as @Maciek rightly pointed out, the boat needed to be places at a distance from the inlet. Finally, the bounding box was altered to keep a distance of approximately 2 boat-lengths to the front and sides, and 4 boat-lengths behind the geometry.
Mesh: There were two main issues with the mesh. The first was about the refinement at the water level not being fine enough to capture the waves. That was corrected by setting a base mesh of discretization of 0.5\text{m} in x, y, and z directions - on top of this, the boat was refined to level 4, and the water surface to level 3. Region of refinement of the water surface was about 0.5\text{m} above and below the water.
The second issue with the mesh was the generation of waves at the inlet in the solution. This was being caused as follows:
  • For this simulation, the inlet was split into air inlet and water inlet. The boundary between these faces was located at -0.4\text{m} in the z direction.
  • However, during meshing, the interface was moved a little since it naturally could not be aligned exactly at that distance. It was a little higher than -0.4\text{m} (-0.375\text{m}, to be precise).
  • When initializing the water phase, I was using a domain-based initialization method, and the height of my cartesian box was exactly at -0.4\text{m}. This was causing the inlet to be a little higher than the initialized domain, and caused the formation of waves at the inlet.
  • After realizing this issue, I modified the cartesian box height to -0.375\text{m}, and the problem was solved.
Solver settings: The solver being used was the LTS (Local Time-Stepping) Multi-Phase solver. In essence, the “time step is manipulated for each individual cell in the mesh, making it as high as possible to enable the simulation to reach steady-state quickly”. It took a while to get the combination working, but eventually stable runs were possible. I ran simulations using two time-steps: 0.005\text{s} and 0.0005\text{s}. Runtime was 20\text{s}.
Steady State for 0.005\text{s}:
Steady State for 0.0005\text{s}:
Clearly, 0.005\text{s} timesteps failed to capture the nuances of the Kelvin pattern of the boat’s wake, while the 0.0005\text{s} timesteps were fine enough to take into account the sensitive wake phenomena.
The following animation shows the solution approaching steady-state with time:
The project will be in a share-ready state by Monday. Thank you for all the help, @quequen, @Maciek! :smile:
Awesome, congrats @sjoshi looks really nice! Do you have the total X force ? Does it converge at the end of the run?
I still don’t understand if the boat is freely floating and triming in your simulation, or is in a fixed position at a certain Z value?
@quequen
Thanks, I forgot to mention this fact: the boat is fixed in space. As you recommended, the water level is assigned such that it submerges the boat upto the point of inflection at the bow.
Here are drag, lift and variable convergence plots:
Drag:
Lift:
Convergence:
Even though the variables seem to converge in the convergence plots, the drag and lift seem to create a pattern that repeats itself over time. Could this be due to the fact that the boat is fixed in space?
Also, as @Maciek requested, here are the pressure and velocity slices at the center-plane:
Hi @sjoshi,
Your results for drag and lift do not look right. I would expect parameters to ramp up to a steady state value.
I’m not familiar with fluid simulation but this problem looks analogous to a solids simulation where the friction penalty coefficient or penetration penalty coefficient is too high. This causes instability over time (in the case of friction, slip and grip or in the case of penetration, bounce). The results look just like this i.e. the solution converges at each time step but the forces are not stable over time. Also, the instability tends to overestimate the forces. The solution in a solids simulation is to keep reducing the magnitude of the penalty coefficient until the solution becomes stable.
The fact that the solution has converged just means that the internal and external forces are balanced at each time step. If the forces oscillate over time the solver simply finds a solution to balance the oscillating forces.
Many years ago I did some testing to measure boat drag. We towed the measured vessel with another vessel using a tow line with a load cell. I remember that the drag force was consistent over time, for a given speed.
As a rough guide you may be able to estimate the drag force with Dave Gerr’s formula.
Assuming:
LWL = 22 ft (water line length)
v = 3.9 kts (velocity)
m = 7000 lb (displacement, just a guess)
The speed length ratio is:
SLR = v/(LWL)^0.5
SLR = 3.9 / (22)^0.5
SLR = 0.831
The required shaft horse power is:
SHP = m /((2.3 - SLR)*8.11)^3
SHP = 7000 /((2.3 - 0.831)*8.11)^3
SHP = 4.14 hp (3080W)
Assuming a propeller efficiency of 55% the drag power is
P_drag = SHP * 0.55
P_drag = 3080 * 0.55
P_drag = 1694 W
Therefore the drag force at 2 m/s is:
F_drag = P_drag / v
F_drag = 1694 / 2
F_drag = 847 N
MODEL POSITIONING
O, now positioning looks much better to me.
Also @quequen let’s don’t push it too much at this stage :slight_smile: Personally I prefer step by step approach. To me it was obvious from the very beginning the model is firmly set in its position. I get your point in terms of tilt (heel?), draught etc. but let’s solve one thing at the time.
Adding tilt is not a problem with cut-cell mesh. Releasing some degrees of freedom may be problematic. In longer term however, yes – definitely. But now, I’d like to see full convergence and full control of the free surface.
INLET CUT
You know what @sjoshi? I also experienced this strange issue at the inlet you had. But in my case I created my domain in CAD program, then cut the inlet surface into two surfaces so that I could later on define them as air and water inlets and only then exported and meshed.
Mesh was generated with no problems. Even mesh division fits to surface division.
(gray – model | red - water inlet surface | light blue – air volume)
Obviously both the surface cut and air/water volume division are at the same height.
I don’t know if it has any significant influence on simulation’s run, but to the record:
step zero
final step (for this particular simulation)
SIMULATION TIME STEP
Previously, based on your animation, I’ve assumed your step was 0.1 [s]. Now, I tested it and see that it was around 0.005 [s]. - It’s just a small clarification.
MODEL
Is it a surface model? In that case, now I understand why @quequen was so keen on z-direction degree of freedom. Why did you decide to run it like this? Any particular reason?
Make your life easier and close it :wink:
Looking at free surface and velocity field it’s difficult to believe that pressure and phase ratio converged so well.
I agree with @BenLewis - forces at your hull look random.
In terms of formulas: I’ll try to find some time and look for it. If I succeed then I’ll ask you for some more details.
RESULTS PRESENTATION
I’d like to add a few words about results presentation – in general.
  • Remember that you see much more than me, @quequen or anybody else, so try to present your material bearing this in mind. For instance: when I presented results of my ROV simulations my main aim was to give basic information about simulation and show correlation rate between experimental and CFD data. I added colourful pictures just to make the topic more vivid, more attractive and eye catching.
Now, when you add your pictures - in my opinion - you can get rid of all that unnecessary elements from it: interface, frames, blank spaces etc. It will make your pictures clearer.
  • Please, for the same case, try to keep to constant ranges if possible (velocity mostly, because it’s something you can control :slight_smile: ).
  • I really like that reversed colour pattern when you present waves coloured with velocity, but…
  • …I’d like to ask you for one more thing here. When you show us waves, plain (not discrete) palette of colours is very good approach. We see smooth velocity changes – super. But when you show cut planes with velocity or pressure fields than it’s not a good idea - at least not always.
I asked you for cuts as I wanted to check the domain vertical size. From what you presented it looks the domain is both too low and too shallow. In terms of the surface model I’ve already mentioned above and I’ll wait for your reply. Here, however, I’d like to show what the problem is - in my opinion.
Below is your picture in two versions (I cut unnecessary blank part at the top and kept the one at the bottom to keep the scale bar):
As we can see in the first picture there’s a lot going on in the upper part. I omit boat interior, but there is something at the inlet too (green band in the right top corner). Also just above the water table air velocity is worryingly high – I assume the velocity fields are bonded and homogenous (both have the same value).
I wear glasses but still can see some barely visible colour patches below the hull. So I took photoshop (free photoshop online) and played a bit. After a minute or two I got this. It seems there is a significant interference of domain’s bottom.
Naturally if you’re familiar with your problem, ran a lot of simulations than you have a feeling and you know where you can turn the blind eye. But here, I think the domain should be higher and deeper.
Maybe some example from my compressible test runs:
wide colour range palette
discreet palette
discreet palette with slightly different range plus velocity plot along the line
As you can see the domain seems to be high enough. But when you go deeper you discover that it should be a bit higher and maybe even longer.
Of course here delta is about 2.5% and probably I can ignore it, but still… That’s why they often have such ridiculously big domains.
Let me know what your thoughts are.
