'CHT test' simulation project by lcltech
I created a new simulation project called 'CHT test':
CHT test
Hi @lcltech, we created a step-by-step tutorial for CHT. You can find it here: Step-by-Step Tutorial for Conjugate Heat Transfer (CHT) Webinar
Hello @lcltech,
I think you are trying to perform a conjugate heat transfer (CHT) simulation. There are certain geometry and mesh prerequisites to setup a CHT simualtion. The geometry should contain the solid and fluid regions as independent volumes which are non-overlapping, but the surfaces touching each other. This would enable to create interfaces between the different regions. Please have a look at the following project for a model geometry for CHT. A trial mesh is also done on the geometry.
https://www.simscale.com/projects/sjesu_rajendra/k62_heat_exchanger_template/1
For a CHT simulation the Hex-dominant parametric mesh needs to be selected maintaining TRUE option for “Create multiregion mesh”. This enables us to setup a CHT simulation. The following tutorials might help you to create the mesh and setup the simulation successfully.
Mesh: https://www.simscale.com/docs/content/preprocessing/meshing/hex-dominant_cht_electronics-cooling.html
Simulation: https://www.simscale.com/docs/content/tutorials/tutorial_cht_electronic_cooling.html1
Please try to create different volumes (solid and fluid) for geometry and follow the tutorial procedures to your problem. Please do not hesitate to contact us for further queries - we would be happy to help :slight_smile:
Sam (@sjesu_rajendra )
