'CHT Heat Exchanger' simulation project by drodriguez32
I created a new simulation project called 'CHT Heat Exchanger':
A test of the CHT capability of SimScale on a heat exchanger.
Change in flow velocity for water (center fluid) and gasoline (surrounding fluid).
Change in temperature for gasoline.
Change in temperature for water.
Temperature of the heat exchanger aluminum casing.
Temperature reduction of the gasoline as it loops around the water.
Velocity profile inside gasoline pipe.
