SimScale CAE Forum
CFD - Raspberry Pi with heat sink
#1
Hello
I don’t understand the tutorial " Raspberry Pi with heat sink"
What is the “block”?
Where is the Raspberry Pi in this example?
Daniel
#2
Hi @daniel11!
Can you post the link of the project? There is one Raspberry project I found: https://www.simscale.com/projects/pgangapatnam/raspberry_pi_-_cooling_1/ - is that a simulation you were looking for?
Hello @jousefm
In my post, I I was referring to the project:
Tutorial - Conjugate Heat Transfer- Cooling of an electronic sink
All the block is the Raspberry Pi?
Regards
#4
Hey there!
The big three blocks (if you mean them) are the USB and Ethernet port which are of no use in this example. The other component that’s big is the heat sink but I think that should be clear. Is this answering your question?
