I am trying to do a CFD for the urban environment for of a city district. However, I receive an error message when trying to generate the mesh.
Link to my project:
Do you know how to solve this?
Many thanks
Matti
Hey Matti,
First, I see the ‘outdated geometry’ message. Can you please re-upload your geometry and try the meshing again? There was a recent improvement on the platform that I think applies to this case, so it should allow you to advance your simulation.
I will also suggest you to use the Standard Mesh algorithm, with automatic boundary layer creation for easy of use. If later you need to tweak the y+ values, then you can try and use manual setup for the layers or the Hex-dominant mesh.
my bad, I forgot to send the link to the new project, see bellow:
Can you see what the problem might be?
Matti
Hi, I noticed that you followed the suggestions from the error message, and was able to create a mesh successfully by selecting a finer configuration.
In case this helps someone with similar issues.
Hi, yes exactly, I changed to very fine and then it worked.
