'Catalytic Converter Exhaust-Porous Media' simulation project by Ali_Arafat
I created a new simulation project called 'Catalytic Converter Exhaust-Porous Media':
Automotive Catalytic Converter exhaust flow analysis using Porous Media.
The analysis compares the flow through an exhaust pipe with and without a catalytic converter.
The catalytic converter is modeled using Porous Media model 'Darcy-Forchheimer' with the following properties:
Porosity: 0.5
mean Diameter: 2e-3 m
Permeability: Isotropic
The local direction (e1) of the Porous Zone is aligned at an angle of 30 degrees CW to the Y-axis as shown in the figure above.
The coefficients ‘d’ and ’ f ’ are calculated from the formulations:
where ‘phi’ is Porosity and ‘D’ is mean diameter.
Results
Pressure Contours (showing relative pressure drops)
Velocity Contours
Flow Streamlines
