'Cassone' simulation project by arossignoli
I created a new simulation project called 'Cassone':
Cassone con fondo apribile
Interesting model @arossignoli, can you tell what this application is about? It seems that you forgot to apply any loads to your structure. What would a typical load cases be? Perhaps I can help to find an appropriate load model.
@arossignoli, @rszoeke - I only added the gravity to the simulation setup to see the behavior of the model under its own load. Check it out here:
https://www.simscale.com/projects/dheiny/cassone
