I have a problem with creating a smaller version of an existing mesh. I duplicated an existing OFMESH, changed parameters and stared meshing. I got following error:
[1] --> FOAM FATAL ERROR:
[1] Cannot find triSurfaceMesh starting from “processor1/constant/triSurface/shell_88.stl”
[1]
[1] From function triSurfaceMesh::checkFile(const fileName&, const fileName&)
[1] in file searchableSurface/triSurfaceMesh.C at line 116.[1] FOAM parallel run exitin
First mesh was created without any problems. Do you know why there is a problem now?
@akosior, can you share the link for the project? One thing you can quickly try is to download and re-upload the STL file to the project and then try meshing.
If that doesn’t work we will need to take a closer look.
