Hello, I’m a university student and I have got a class project on simscale. The Instructor wants me to model following heat transfer problem in simscale and then analyze it. For an analytical solution I’m okay but I have got no analysis software experience before. So please help
- A pipe carrying oil and having a diameter of 0.6 m is buried in soil of conductivity 0.6W/mK at a
depth of 6m. The surface temperature of the pipe is 80°C. The surface of the soil is at –10°C.
Determine the heat loss from the pipe for 1 m length. If the velocity is 2 m/s and the density is
900 kg/m3 and specific heat 2000 J/kgK determine the temperature drop in flow through a distance
of 100 m.
** This problem will be solved as :
a) Create a solid geometry of the problem as a thin plate to perform 2D analysis.
b) Transfer geometry to SimScale.
c) Create Mesh (Tertrahedral of hexahedral)
d) Impose boundary conditions. On front and back surfaces of the plate, impose insulated or symmetry bc to simulate 2D problem.
e) Solve the problem and postprocess results for the quantities asked in the problem.
Solve the problem with 3 different mesh densities (Coarse, Medium, Fine) and compare these results with shape factor results.
