I need some help to setup a multiphase simulation that involves the formation of gas bubbles in a liquid. The initial flow is laminar and without gas, then the bubbles are formed on a surface within the liquid based on known parameters (chemical reaction).
Is that something that is possible with Simscale ? Any help is very welcome
Simulations with bubbles in SimScale are possible (e.g. this validation case), however we don’t explicitly support chemical reactions at the moment.
You could ‘generate’ bubbles in the system by setting up inlet boundary conditions where air goes in, or via initial conditions (like in the validation case).
Thank you for your answer.
Ok, this could work to some extent. I will try it !
