'BRZ Aerodynamics Scaled' simulation project by lesterneo
I created a new simulation project called 'BRZ Aerodynamics Scaled':
Scaled version
True to scale geometry used.
Auto snappyHexMesh for external flow. Problems encountered with anything higher than level 1 meshing.
Hi @lesterneo
I just copied your project and created a “New Auto SnappyHex Mesh” with “level-3 Moderate” fineness and there were no problems. Could you be precise what happened in your case ?
Please try again by creating a New “Auto SnappyHex Mesh” with “level-3 Moderate” fineness with 16 processors.
Let me know if you still have issues.
Ali
Also, Your geometry is a highly detailed, I would suggest that you simplify it to remove non-important things like the roof antenna, wind screen wipers , other small parts etc, if possible.
Other wise try a Manual “SnappyHexMesh” with full control over refinements ,
A basic tutorial is here : https://docs.simscale.com/docs/content/preprocessing/meshing/snappyHexMesh-ahmed-flow.html
A Sample project with Manual “SnappyHexMesh” : https://www.simscale.com/projects/Ali_Arafat/aerodynamics_analysis_of_a_formula_one_f1_race_car
I hope this helps.
Ali
#5
Thanks for taking a look at this simulation Ali, was just using the comment section to keep notes on this project. Didn’t expect anyone to respond. :yum:
Anyway, I will give both the level-3 moderate a try and manual meshing refinements a try as well.
#6
Hi @lesterneo
Its good to see your level-3 mesh went successful. Be sure to tag me by typing " @Ali_Arafat " so that I can get a notification of the conversation.
let me know if you need any help. ok
Ali
