'BOQuad' simulation project by apils
I created a new simulation project called 'BOQuad':
BOQaud
Hello @apils!
I saw that you had several simulation attempts without any results. Could you tell us a little bit more of what you want to achieve? I am sure we can find a solution to your problem and make this work :+1:
All the best,
Hi!
I replied by mail but it looks like it didn’t work.
I tried to recreate the same analysis as in the drone workshop with my own geometry but all the simulation-runs failed.
Regards, Alex
Hi Alex,
I will have a look at that and come back to you as soon as possible!
hi @jousefm!
any idea why the simulation didn’t work?
regards,
alex
#6
Hello @apils!
I saw that you had a successful simulation a week ago? Why did you delete it? Weren’t you satisfied with the results?
I am assuming that there have been problems with the contact definition of the master-slave assignment. If you set those up In a proper manner, there shouldn’t be any problems at all (except some other numerical miracles that might occur).
If you have any questions, please let me know :slight_smile:
hi!
i modified the simulation to linear static with all bonded contacts to verify that my cad model or the mesh is somewhat useable. but i wasn’t able to get results with physical contacts.
i think you have a copy of the original simulation in your projects.
could take a look at the contacts-setup there? thanks!
alex
