'Bearing Thermal Response' simulation project by Burcak
I created a new simulation project called 'Bearing Thermal Response':
Thermal stresses on the shaft, the housing, and the bearings
@Burcak,
currently there is no “automatic contact” definition functionality on SimScale, this means you need to set the kinematics between the parts of an assembly manually. With 20+ parts, this is very elaborate, so depending on where the same material is used, I’d recommend fusing those parts before the upload.
An automatic contact detection will be available in the future, which will make things easier!
David
