'Bearing' simulation project by vjoshi95
I created a new simulation project called 'Bearing':
Bearing Analysis
Hi @vjoshi95!
Nice CAD model! Did you create it by yourself? If you are not interested in the forces acting between the cage and the bearing balls you can just remove the cage and make sure that you cut the model in halves as the problem is symmetric.
