BC: "periodic" or combination of "velocity inlet" and "pressure outlet"
Hi everybody,
for a LES I used “velocity inlet” and “pressure outlet” BC. From several tutorials I understood such BC as good standard. However, a college suggested to use periodic BC instead, as this was a good method to prevent horizontal boundaries having an effect on the wind flow.
What do you think?
The aim of my LES is to show, how two different shaped walls provide protection from wind. Here is a link: https://www.simscale.com/workbench/?pid=1929720385875739693&mi=spec%3A7cb9aa7a-6165-4b57-9646-fc992f7caa7e%2Cservice%3AMESHING%2Cstrategy%3A7&ps=geometryPrimitives%2F0&sh=6
I also shared the link with support, I am taking about run2.
Thank you!
Sophie
Hey :smile:
The periodic or cyclic boundary condition (BC), defines a cyclic/repeating situation of the flow across the boundary surface. For this condition, it is mandatory to select two boundary faces that will be treated as if they are physically connected. The flow exiting/entering from one face then enters/exits the other face. (you can learn more about it here if you want: Periodic (Cyclic) | Boundary Conditions | SimScale)
So for your case, the combination of a Velocity Inlet and a Pressure outlet should work just fine. The horizontal boundaries are set to Slip walls, meaning that the normal component of the velocity is erased and the tangential components remain untouched at the assigned surface, so their effect should not worry you.
You can check some external aerodynamics tutorials with a similar setup:
Thank you!
