'Assesment' simulation project by nikhil_kale
I created a new simulation project called 'Assesment':
This is a simulation of a component used in a Machine Tool. Component is a guiding and mounting plate. CAD model was completed using SolidWorks and then imported into SimScale project using standard STEP format.
Mesh Refinement - Layered Mesh is used at the load faces and support faces to generate more accurate transition of results from the bulk of the component towards the boundary.
Interesting project!
Did you encounter any issues while performing this simulation?
