'Arm test' simulation project by mike_werff
I created a new simulation project called 'Arm test':
Test arm
Hi @mike_werff,
I was looking through some of the public projects and I noticed your project has a failed mesh. I quick look shows only faces in your model, it does not have a solid body defined. You may want to check in your cad system to make sure the part shows as a solid. Also, Step files work better than Iges files. I am not sure what format you used.
Good Luck!
Christopher
Hey @mike_werff!
As Christopher (@cjquijano) mentioned, you need to upload a geometry containing solid in order to mesh it (preferably in .step format). You can have a look at [this] (Can a tetrahedral mesh be created using geometry with only shells/faces?) forum post for more help.
Good luck!
-Ahmed (@ahmedhussain18)
