I created a new simulation project called 'Apenas Full_1':
Apenas Full simulacao escoamento externo
Hi @ib01,
I just took a look at your model - there seems to be an issue at the front of the aircraft:
There is a face missing which means that the geometry is not watertight, which leads to the fact that mesh is actually generated on both sides of the model:
Once you fix this face, the sim will be straightforward. What CAD system are you using? Where did you export this STEP file from?
David
Hey David! Thank you for the heads up! Very thoughtful of you. Something probably went wrong during the file upload. Now it seems to be ok. Thanks again.
p.s.: I’m using solidworks.
Regards.
