I am very new in SimScale and I have problems running my simulation. I want to calculate the local heat flow on a planetary surface, so I have started with a very simple geometry to carry out a first test and I have followed the Thermal Analysis Tutorial step by step.
This is my project: https://www.simscale.com/workbench/?pid=4411223043849453753#tab_0-0
Apparently, I imported and meshed the geometry successfully, but when I run the simulation I got this warning:
An entity name with more than 24 characters was found. This is not allowed for the Code_Aster solver
Then, the simulation stops. I have also found this error in the Simulation Run Even Log:
groups edgeGroupOnGeoEdges_22810 and edgeGroupOnGeoEdges_22811 !
! have same twenty the first four characters, their name !
! short is thus edgeGroupOnGeoEdges_2281. !
! As it is not legitimate in the general case that two !
! groups with the initially different names are amalgamated,!
! computation stops.
Any help in resolving this issue would be greatly appreciated.
All the best,
Isa.
