'Airflow around a football' simulation project by murat_bayram
I created a new simulation project called 'Airflow around a football':
The air flow around a football is simulated with focus on the effects of the pattern on the football surface and spinning of the ball.
Hi @murat_bayram - nice job with the tutorial; One thing with the Bounding Box discretization:
The cells in the x, y, z should be 46, 46, and 47 respectively to improve the mesh fineness
Thank you @AnnaFless, I must have overread this in your tutorial. I did the run again, unfortunatly I have Problems with the post-processing. I somehow can not see my results.
Hi @murat_bayram,
Can you share a screenshot? Do you mean that nothing appears when you select the solution fields in the Project Tree?
#5
Good Morning,
yes. When I click on Solution field the Screen seems to be frozen. De weiting Symbol is not rotating. I tried it with different Browsers.
#6
With Chrome it actually worked. Was not working with Firefox, Safari or IE.
This task was a very nice simulation workshop. Thank you!
#7
Hi @murat_bayram, glad you were able to get it to work using chrome! I’ve let my colleague @bdaqui know so we can have a look into why it’s not loading on these other browsers.
Thanks,
Anna
#8
Thanks for the fast feedback.
The more I have to do with the simulation tool and the forum I´m getting more and more excited.
#9
Clad to hear that :smile:
Can I ask you to provide us some debug information? In Firefox,when you are in the post-processor before clicking on ‘solution field’, do a “control shift J” then attempt to load, and if it does still not work, post the output.
