'Aircraft engine bearing bracket analysis' simulation project by ahmedhussain18
I created a new simulation project called 'Aircraft engine bearing bracket analysis':
This project demonstrates the static stress analysis of three aircraft engine bearing bracket models considering both linear and nonlinear material definition. The models used in this analysis are taken from GrabCAD users who were the winners of GrabCAD 'Airplane Bearing Bracket Challenge'. The models are tested with horizontal and vertical loading conditions as provided on the challenge page of GrabCAD.
This project is the completed homework of Workshop 2 Session-2 Homework: Aircraft engine bearing bracket analysis
pls share geometry
Hi @prudviraj_eluri!
You can download the geometry inside the Mesh Creator tab.
Let me know if everything worked and if you have any further questions.
