# 4-bar linkage stress analysis
**URL:** <https://www.simscale.com/forum/t/4-bar-linkage-stress-analysis/81630>\
**Category:** Solid Mechanics / FEA\
**Created:** [February 8, 2018, 8:43pm UTC](https://www.simscale.com/forum/t/4-bar-linkage-stress-analysis/81630 "2018-02-08T20:43:26Z")\
**Showing post:** 19
**Author:** ![ahmedhussain18](https://www.simscale.com/forum/user_avatar/www.simscale.com/ahmedhussain18/32/140_2.png) [@ahmedhussain18](https://www.simscale.com/forum/u/ahmedhussain18)\
**Post date:** [March 6, 2018, 8:47am UTC](https://www.simscale.com/forum/t/4-bar-linkage-stress-analysis/81630/19 "2018-03-06T08:47:20Z")
Hi @Pavol_Kianicka
> [@Pavol\_Kianicka](#):
> 1, Do you think it would be possible to mimick the kinematics of 4bar linkage for the sake of stress analysis the same way as you did it? I mean, I would just set-up contacts between particular assembly parts, set the coil spring material properties to match desired spring stiffness, and then only specified displacement constraint (boundary condition) to make the assembly compress the spring?
Yes it is possible and you can do so. You can either make a physical spring which will add up more complexities in your model or ideally one can also make use of elastic support but problem here is that the grounded node of the elastic support initially is by default taken on the node on which elastic support is defined. Therefore, one can’t use it exactly as a properly defined spring. But you can have a look at this project where elastic support is used to mimic the spring behavior: [FEA of Pneumatic Actuator with Spring & Elastic Support](https://www.simscale.com/projects/ahmedhussain18/pneumatic_actuator_with_spring_and_elastic_support/)
Here spring is replaced by elastic support. More on elastic support you can read here: [Elastic support](https://www.simscale.com/docs/content/simulation/model/boundaryConditionTypes/ElasticSupport.html)
I think you can initially make use of elastic support to mimic your spring behavior.
> 2, How did you make the screenshots where original state of your assembly is displayed in gray-shade?
It was done in Paraview locally but now can be done also in online post-processor. As an initial post-processing guide, please see here: [FEA post-processing guide (using online post-processor and local Paraview)](https://www.simscale.com/forum/t/fea-post-processing-guide-using-online-post-processor-and-local-paraview/29896)
> 3, How am I supposed to set-up Mesh generation operation to make it successfully finish the job and create the mesh?
First you need to start with a smaller model. Take a simple example and once succeeded with it than try to add more complexities. Whenever you deal with meshing, try to simply your model as much as possible. If you have similar materials for different assembly parts firmly connected to each other, try to merge them before upload to decrease effort in defining the bonded contacts. It will also in turn make your simulation faster. In current model case of yours such similar problems exist. Specially the threading on one of your part which you must remove because it’s always hard to mesh such faces.
Hope this helps.
Ahmed
_[View the full topic](https://www.simscale.com/forum/t/4-bar-linkage-stress-analysis/81630)._
